SL/R230: Scanners
Xentry is the "rolls Royce" tool (or is that S-Class tool
). It is the factory tool, but it can not do everything Mercedes can with it though. It is the best diagnostic scanner, and the only one that has comprehensive "Guided fault finding" (If a code is found, it tells you how to investigate further, such as read a voltage at a certain place, then gives next step depending on voltage found). It is very comprehensive!!!You can do variant coding, which can add features to the car. You can also control most things from the laptop, including lights, windows, seats etc as well as see all the inputs in real time. There is also an engineering mode, which is where you can **** things up! It is the best diagnostic tool. If you become an enthusiast you can add vediamo, which will give you control module back ups, as well as out of car access to modules. However getting a working system is time consuming and requires a lot of patience, and a lot of computer tinkering. Not too expensive if you already have a suitable laptop There are no manuals, so a lot of research needed to get running with it.
Next level are Mercedes specific diagnostic tools, like iCarsoft, Autel foxwell etc. These are good home mechanic tools, and will give codes and descriptions for most modules. Some can even actuate things on the car, but basically they are comprehensive code readers/code reseters. I cary one in the car when travelling, just in case.
Finaly generic ODBII code readers. Forget these
Why so many different ones? I acquired them over time. The Autel is the only multi-brand scanner of the group. Actually, you can add car brands individually to the Creader Elite, and I do have a BlueDriver scanner that will do multiple vehicle brands.
Lastly, I agree, don't waste money on a generic code reader.
They also come with a DAS simulator, so you can explore a bit offline and get a plan together for actual work on the car. If you have a few issues, you can verify which modules control that function. For example, if you have a gas gauge problem, you can find which module reads the sensor and how to test it, go to WIS to find a wiring diagram, and then to Star Finder to see where the module, ground points, etc. are located. If you determine the sensor to be defective, you can find the correct p/n for your specific vehicle in EPC and replacement procedure in WIS. An aftermarket code reader will just give you an invalid fuel sensor reading in the Rear SAM and the rest is up to you to figure out somewhere else.
