SL/R230: What's the difference between DAS and Xentry?
I think that's because I don't have the multiplexer gadget. I've just ordered one off Aliexpress for $300. I know it's a clone, but I hope it will do what I need. Primarily I need to diagnose the roof and do things like actuate the flaps etc. The one I've ordered is the Mbstar C4 wifi no DOIP.
My question is; will it work with Xentry or do I need the older DAS software?
Also, if your system included WIS/EPC and Starfinder, make sure that you can run those. They are essential to diagnosing and repairing any Mercedes.
The adapter you have is probably a "passthrough" device and runs on a passthrough version of Xentry which you will likely have been supplied
Your new C4 multiplexor will require the "openshell" version of Xentry. The version I have is 2021-12.
Software can be found for free, along with activation code generators, but is not a straight forward install. It is over 22Gb. It will run on windows 10.
I am not sure I am allowed to post the download link, but PM me for information.
Open shell is used for the Multiplexors (C3 and C4), and this is the version needed for our older cars (R230), as they are a combination of K-Line and CanBus communication.
Passthrough is for newer cars, and is just CanBus connection. This is a much simpler connection interface, and common amongst many vehicles, but will only communicate on CanBus, so will not talk to most modules on R230. This will be what the OP was originally supplied with. The interface can be purchased for $30 or less such as VAS5054 clones.
Both versions are identical to use, just the connection interfaces are different.
All versions of Xentry (DAS) have developer mode, but you need the correct STARTKEY to enable it.
I'm now left with one fault which tells me that the boot divider needs to be closed. I have stripped out all the boot linings and shorted out the connecter for the divider microswitch, but I'm still getting that error. Time to peel back the bundle wrapping and look for a wiring fault.
.Electrical drawings for 2003 to 2008 models
Another work in progress. So it looks like I need to get the pneumatic system fully working to get the roof to work!
i can see the successful thread, and would like assistance in interrogating the car’s Dual Battery R230 Dual Battery and resetting of
On-board Electrical System, including DTC’s set in the vehicle power supply control module (N82/1).
Seems the BNS unit (boot) is indicating high resistance and slowly cooking the System battery.
Any assistance would be much appreciated.
https://mbworld.org/forums/sl-class-...a-s-n-1-a.html
1. Laptop -- Lenovo ThinkPad X200 series (X240, X260, X270, etc.) available refurbished on Amazon.
2. C4 Multiplexer with DoIP -- Contact @BenzNinja for a good source.
3. DAS/XENTRY software -- Join the BenzNinja Club and get the software that runs natively on Windows 10. No virtual machine nonsense.
