SL/R230: How to move stuck rollbar cylinder & identify fault??? roof won’t open?????
How do I move stuck rollbar cylinder & identify the fault?
The rollbar cylinder or its assembly component seems at fault. I detached the solenoid from the rollbar, pushed it down to lock onto the connector at the top of the cylinder rod, and the console switch operates the roof until I stop before the rear window interferes with the rear window shelf. (Before I attached the solenoid to the rollbar cylinder, the center console roof switch would only move the trunk lid straight up, get stuck; and would not reverse to close.)
The rollbar cylinder will not move. When I push the rollbar down center console button, the pump runs for about 5 seconds then stops as if it is confirming the rollbar is down. When I push the button up the rollbar cylinder does not move. (Before the rollbar up or down buttons would not move the cylinder.)
How do I get the cylinder to Move????? I have a used rollbar assembly. Do I switch solenoids… this seems easiest. Do I switch rollbar assemblies, just the cylinder, or the double up down limit switches? If switching component(s), does not get the cylinder to move, do I replace the cylinder with a rebuild?
---------------------1 of 2 Frame---------------------
560 Vehicle speed 0 mph
536 Rollover bar switch : NOT RECOGNIZED
'Raise' function operated
537 Rollover bar switch : NOT RECOGNIZED
'Lower' function operated
600 Magnet test faulty NO
370 Rollover bar lowered RECOGNIZED
371 Rollover bar raised NOT RECOGNIZED
520 Ignition ON YES
530 Voltage supply is o.k. YES
531 Pump temperature OK YES
532 Switch Vario roof not YES
operated
533 Limit switch OK YES
534 Activation of rollover bar YES
NOT ACTIVE
535 Actuations using diagnosis YES
NOT ACTIVE
