Gentlemen, After having issues with a bad rear battery, replaced the battery and soon later I started getting a Check engine Light...I cannot speculate if that is related or not, but the description of the fault is as follows:
Vehicle runs normal with a little hesitation when accelerating without changing to the lower gear.
P2037-004 No or Incorrect CAN message from control unit N15/3 (ETC [EGS] control unit) Communication fault/ See also CAN status in freeze frame data (P0600) P202F-004 CAN message from control unit CGW or EZS is missing or faulty. Communication fault/ See also CAN status in freeze frame data (P1999) or
no or incorrect CAN message from control unit N51/2 (ABC control module) Communication fault.
I wonder if anyone have come across to such fuzzy description. So far I am lost around that terminology..!
Mike, digging into the subject I could see that the two modules addressed by the DTC's are branches of the CAN C, but the document I got
tells that the connector is in the driver's side door sill.!
