SL/R230: SL/R230Load Separation Module Needed
Old Dec 24, 2023 | 05:49 AM
Duckmoore123's Avatar
2005 SL 500 R230
Hi. I have a R230 2005 SL with 50,000 miles that’s in pristine condition that hasn't
been driven in over 3 months due to not being able to locate a Load Separation Module (or some call it a BCM) because The Mercedes Dealership says that they STOPED producing this part and it’s no after market parts available! So my car is just sitting in my garage! Can anyone help me with this problem or guide me in the right direction? Any help would be deeply appreciated!!!
Old Dec 24, 2023 | 08:30 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
If yours is not burned, there are electronics repair shops that will fix them. Otherwise, they are available on Ebay, just pricey right now. Are you 100% sure that yours is bad?
Old Dec 24, 2023 | 04:42 PM
2005 SL 500 R230
Thanks for responding. That’s what the Eletrical repair shop diagnosed. They checked everything from the front to underneath the passenger glove box to the rear trunk. Visit workshop malfunction warning stays on. Most of the conveniences are not working, such as windows don’t close all the way, seats controls work strange, and overheads lights don’t work.
Old Dec 24, 2023 | 05:16 PM
g0rsq's Avatar
SL500
Get it diagnosed properly by independent Mercedes specialist using STAR SDS system.
Your symptoms don't sound like BCM failure. Mercedes R230 is out of the realms of an auto electrician!
Effectively all BCM does is keep the two batteries isolated (unless one is low voltage), and regulates the charging of the starter battery.
If you have two fully charged batteries everything should work as normal, unless you have a "consumers off line message, but car will start and run.
Old Dec 24, 2023 | 06:33 PM
2005 SL 500 R230
Thanks for that info! I do have 2 fully charged batteries and new alternator. I will need to get it towed for the third time now to Mercedes. I’m at $2,000 already😊
Old Dec 24, 2023 | 06:58 PM
g0rsq's Avatar
SL500
Ouch. That must hurt.
Without full diagnostics you may be spending several times that...
A lot of Mercedes dealers just are not interested in 20 year old cars. Cant you find a trusted independent Mercedes specialist?
Old Dec 24, 2023 | 08:43 PM
2005 SL 500 R230
Thats a good suggestion! I will try to locate one after the Holidays and check with the MB dealership!
Old Dec 26, 2023 | 07:29 AM
Tom Manning's Avatar
2005 SL 500 R230
Hmmm. Who's this workshop? R230 needs specialist knowledge, not an MB dealer. They don't know diddly-squat about the R230 now. Too old. Few here would go near one.
As mentioned, probably not the BCM.
Visit workshop malfunction warning stays on. Common fault after rear battery gone flat. Clear the code with a hand scanner such as Foxell.
Most of the conveniences are not working - do you have the 'convenience features unavailable'? If so, charge up rear battery and it will go.
Windows don’t close all the way - hold up both switches fully for three seconds until all four windows close fully.
Seats controls work strange - tell more
And overheads lights don’t work - check all fuses in all three fuseboxes - always the first thing in any elec. diagnosis on any car...
Old Dec 27, 2023 | 08:18 AM
JettaRed's Avatar
Veteran: Army
Sorry, but spend a little more and get a CORRECT scanner. I recommend a Mercedes-specific scanner, such as iCarsoft MB V3.0, LAUNCH Creader Elite BENZ, or Foxwell NT510 Elite. You will be able to scan your car at any time and not rely on others that may not know what they are doing or have the right equipment. On Amazon, they are pretty inexpensive compared to what I've seen them sell for elsewhere. They are small enough to store in your car (such as the fuse compartment in the trunk). Sometimes a code may cause the car to run rough and clearing it will restore normal operation until you get a chance to check it out. (Do not waste your money on the iCarsoft MB II. It is slower and requires you to check each module for codes. MB V3.0 runs an automatic scan and will identify modules with DTCs so you don't need to check 30 or 40 modules individually.). My personal favorite it the LAUNCH Creader Elite BENZ.
Old Dec 28, 2023 | 08:35 PM
2005 SL 500 R230
Sorry for taking so long to respond, but you are saying that it may not be BCM? Tomorrow I will try to find someone with those test tools. I’ve called several shops today in New Orleans and no one said the have what is needed to do the test on it. This is so troubling. Thanks so much!
Old Dec 28, 2023 | 08:45 PM
2005 SL 500 R230
Hi. From the initial Question was that it’s all new batteries and alternator. All fuses are good.
Old Dec 28, 2023 | 08:47 PM
2005 SL 500 R230
Thanks again,but Amazon is sold out.
Old Dec 28, 2023 | 09:34 PM
MikeJ65's Avatar
I assume that that is referring to the Launch Creader Elite Benz. It is literally an Amazon lightning deal right now, $119.
Old Dec 28, 2023 | 10:00 PM
2005 SL 500 R230
Grab it, you will need it again!
Clear out the codes and see what comes back. Battery light message will likely go and stay out now.
Old Dec 28, 2023 | 11:00 PM
2005 SL 500 R230
Yes and thanks.
Old Jan 3, 2024 | 05:41 PM
2005 SL 500 R230
Thanks so much for the correct advice! IT was not the BCM! So for it was a low Secondary Battery. Took it to a older person that specializes in MB"S.
Old Jan 3, 2024 | 05:47 PM
2005 SL 500 R230
Thanks! took it to an older MB technician and it was a low secondary battery. I saved a lot of money after a miss diagnosis of a bad BCM.
Old Jan 3, 2024 | 05:50 PM
2005 SL 500 R230
Thanks! it was a low secondary battery and not a bad BCM. went to a Mercedes specialist..
Old Jan 3, 2024 | 07:05 PM
2005 SL 500 R230
Good work. Failed rear batteries are common. Hope they fitted the right AGM battery...
Old Jan 3, 2024 | 07:47 PM
MikeJ65's Avatar
Speaking for all of the older MB specialists out there, that is often what these cars need. Glad you got it sorted without spending $1500 on a used module.
Old Jan 4, 2024 | 05:13 PM
cdk4219's Avatar
95 SL600
These cars are going to be getting cheap when used bcm s are $2000
Old Jan 4, 2024 | 05:36 PM
MikeJ65's Avatar
Pretty sure that we can figure out a replacement for less than $500 that has a side benefit of not catching on fire.
Old Jan 4, 2024 | 08:23 PM
cdk4219's Avatar
95 SL600
That would be nice.
Old Jan 7, 2024 | 06:32 AM
HLG600's Avatar
2009 SL63 AMG
I'm sure that gentleman who has been rebuilding M275 / M279 coil packs could figure out a solution.
