SL/R230: R230 Rear subframe bushing replacement
Jack and support the car on rear side with enough room to drop the rear. a little higher than normal. you will need to slide under the dropped suspension.
put jack under rear
remove the 2 flat bars that go from side to the center
remove support for exhaust at rear of transmission tunnel
pop the mufflers off the rubber hangers. you cant do it without doing this
take lower bolt off struts
cut the wire tie on the angle sensors? that is behind the control arm in the center of the car. the wire goes up through the floor. keep your eye on this as you drop the rear as to not stretch.
remove clamp for strut hose on floor. not sure if this is needed but it is easy
take out the 4 subframe bolts. take note of the washer on the forward bushing for direction. then lower the subframe slow!
keep your eye on the angle sensor wire
if you have a second jack you can jack one side under the control arm to make the opposite side drop lower for room
when you put the tool on dont let it try to thread into the bolt hole above it. it may damage it then you are fd
not orientation of bushings so the are installed in the proper direction. use other side as guide or take a pic
put it all back together.
I may rent out the tool or sell it. Or keep it. I am sure I will have another SL
Is this the kit https://www.germanspecialtytools.com...230-front-rear
Has anyone done the job without the kit? Seems really expensive.
Jack and support the car on rear side with enough room to drop the rear Deck Builder Arlington. a little higher than normal. you will need to slide under the dropped suspension.
put jack under rear
