SL/R230: SRS light - Right side airbag and window airbag
is this a possible fuse issue? Cable chafing under each seat?
Can anyone point to a testing process clip in youtube etc to help me narrow this down. I will be searching.
(Update) MB11 shows buckle/unbuckle works on both seats, so i have a working circuit there. Next checking harness under seat for damage that would cause the 'short' to ground, then sensor itself.
Right now I have no idea how to proceed.
I would greatly appreciate it if you could update if you find the error. I will do the same.
Disconnected all, and re-seated multiple times. Cable tied lower hanging wires to tie points (obvious had been played with at some point in the past).
MB 2, by icarsoft was still having an issue when I attempted to read and clear faults, so updated code, reran the diagnostics, no errors, was able to clear SRS error and light off 😀
Early days, but SRS light remains off after several drives.
