SL/R230: How do I Remove Windshield Water Collector Find Leak at Firewall Culprit?
Old Jan 30, 2024 | 08:27 AM
aegea's Avatar
2004 SL500AMG, 2003 SL500 USA
Question How do I Remove Windshield Water Collector Find Leak at Firewall Culprit?
Per Benzbits, how do I unclip water collector out of mounting rail?
See Remove/install water collector (benzbits.com)
See FG 230.475 - WATER BAFFLE WITH INTAKE SHELL > Mercedes EPC Online > nemigaparts.com
Old Jan 30, 2024 | 09:58 AM
DavidCA's Avatar
SL500 2009
This part just lifts up from the glass but you will think that it is glued, it isn't, you need some thin plastic wedges or similar to pries it up from the glass.
There is a very good chance you will crack it as it will be brittle, try to be gentle and work your way along it a little at a time.
It can be done, Good Luck.
Old Jan 30, 2024 | 04:40 PM
aegea's Avatar
I used PBlaster, a thin plastic wedge, and a toothbrush to soak the mounting rail for an hour, then wedged the top edge of the water collector up/perpendicular to the windshield. I pried the hose away that was clipped to the rain/air box, & removed box. Then I removed 3 hoses and an electrical connector from the leaking heater control valve A230 830 00 84. The valve was $25.69 on Amazon with 2 day shipping when I subscribed to Prime.
