SL/R230: fuse tap
Old Feb 15, 2024 | 07:29 PM
njbiker2008's Avatar
sl 500 r230
fuse tap
I need to know the best fuse to tap into for acc 12v and were is it i need switched 12v t/k you
Old Feb 16, 2024 | 12:47 AM
Tom Manning's Avatar
2005 SL 500 R230
Here's Frederick's fuse chart.
https://www.benzworld.org/threads/r2...grams.2898505/
Might be helpful.
See if you can tap into the radio circuit?
Old Feb 17, 2024 | 09:40 AM
sl 500 r230
T/K you
Old Feb 18, 2024 | 05:10 PM
g0rsq's Avatar
SL500
Depending on the radio fitment it wont have a switched 12V. Switching is done via CANBUS.
Depending on where you need the switched 12V you could consider the cigarette lighter socket.
Most fuses are permanent 12V, but the fuse list is a good place to start.
