SL/R230: Misfires when cold
If I leave the car idling, the engine eventually warms up and then - almost all of a sudden - starts to run completely smoothly. From that point on it's golden; no misfire, lag, or loss of power.
Any suggestions/advice on what to look at first ? MAF, any particular vacuum line, some temp sensor ?
Advice appreciated !
I don't get any DTCs from OBD - except for the cylinder misfires. What would show up in a scan if the coil pack was going bad ? (Besides a misfire )
Scan with Foxwell or Launch CReader or similar and post up the codes for comment.
So I follow the discussions on the subject - this is the world expert on the V12 coil packs: https://www.v12icpack.com/
It's got the full MB package, but is very slow; I think they all take the same time to scan though.
If you get the Launch, please do report back, I'm interested in seeing a review of it.
I ordered this one: "LAUNCH X431 Elite 2.0 Pro Bidirectional OBD2 Scanner Fit for Mercedes-Benz MB Sprinter Maybach, 2024 Full System Diagnostic Scan Tool, All Reset Service,ECU Coding,Key programming,"
I'll give it a run through and let you know how it goes.
There is something that's causing non-ideal fuel-air mixture when cold. Then all of a sudden it corrects. What component corrects so dramatically ?
I'd love for a scanner to help point in the right direction. Other than that I have to start diagnosing/testing/swapping any sensor that is in that decision making chain (i.e. IATs, MAFs, vacuum hoses, etc....).
Look forward to your report on the Launch. I agree the Foxwell has a very 1990s look and feel about it...
If I leave the car idling, the engine eventually warms up and then 신용카드 현금화- almost all of a sudden - starts to run completely smoothly. From that point on it's golden; no misfire, lag, or loss of power.
