SL/R230: Dome Light not Working (module N70)
Old Apr 21, 2024 | 03:21 PM
BeanMeansCLS's Avatar
SL55 AMG
Hi - recently had to disconnect batteries from the car for a while whilst my BCM was getting replaced, once I reconnected everything I noticed that my dome lights weren't working as well as the roof thinking it was open when it was closed.
Scanned the car and it seems like I can't communicate with the overhead control panel (OCP - the dome light module), I've checked the fuse for this (fuse 38) and it seems okay...is it likely that it's just died? The lights have flickered before a few times in the past few months...
Does anyone have a pinout/wiring diagram for the dome light module so I can check if it's even receiving power?
, there's no communication to the
Old Apr 22, 2024 | 03:04 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Power/ground are connector B, pins 4 & 6. Red/violet for power and of course brown for ground.
Old Apr 22, 2024 | 03:43 PM
SL55 AMG
Thanks, just checked and it's getting 12v power, assumed board has gone kaput so have ordered a 2nd hand one to test....hope it works!
Old Apr 23, 2024 | 04:12 PM
SL55 AMG
So I fitted a used dome light today, everything seems okay so the old one must have had a fault on the board...however we now have 2 new problems:
The first is that the onboard temperature sensor seems to show a strange value? I've checked the thermistor and it's showing 10kOhm which I believe is correct (goes up and down with temperature changes). Climate control seems to be working ok though? Not sure what this means.
The second is that I now get an error B1643: Component B38 (rain sensor) communication error or circuit fault and my auto wipers don't seem to be working (tested with water spray)
Any ideas?
Old Jun 16, 2024 | 06:06 PM
MR.AMG.'s Avatar
SL55 amg R230
Hi can you please tell me where the connector is i am trying to trace the same fault code
uk
Old Jun 17, 2024 | 11:44 AM
SL55 AMG
Hi MrAMG, which fault are you referring to?
Old Jun 19, 2024 | 04:56 PM
MR.AMG.'s Avatar
SL55 amg R230
Hi thanks for replying i have traced the fault and found some corroded wires.. would you know the cable size i could use?
