SL/R230: Valve Cover Gasket
Old Apr 22, 2024 | 12:03 PM
TxBenzIn's Avatar
2003 SL500 (70,000)
Valve Cover Gasket
I had the dealer do a LOF, and a MultiPoint Inspection a couple weeks ago. They noted that the Valve Cover Gasket needs to be replaced. I looked on both sides and didn’t really see any signs of leaking. There is nothing on the garage floor either.
I do notice that after I park it, I can faintly smell a burning smell. Could that be related?
maw suggested I swap the plugs and do the gasket at the same time so I’ll get that scheduled with my indi- just curious if it’s related or just how these cars smell after a good run.
Old Apr 22, 2024 | 12:42 PM
HLG600's Avatar
2009 SL63 AMG
M113 valve covers have 2 parts. The main seal is via a replaceable rubber gasket. There is also an upper part that is sealed via (optimally) an MB-specific RTV.
That faint burning smell is most likely from a small leak making contact with the exhaust manifold(s).
Plugs on this platform are side-access and there are 16 of them. Can confirm it is notably easier to replace them with the valve covers off.
Old Apr 23, 2024 | 10:10 PM
marcd7tx's Avatar
E500 Wagon, SL63 IWC, E450 Wagon
Those M113 valve covers are finicky, I have replaced those on my old SL500 and on my E500. They still seep, but don't overtighten the torx bolts to try to solve that. Just resealed the breathers after a multi stage cleaning and using MB sealant, but they are seeping as well. Upsetting to say the least. Some say use only the MB gaskets, as opposed to the OE aftermarket AND to add some sealant to the valve covers BEFORE seating the valve cover gaskets into the VCs to ensure a solid seal.
Plugs can obviously be changed with the VCs on, but much easier while they are off especially since, depending on age/mileage, those ignition coil boots can be a pain to remove off the plugs.
My E500 only "smells" when the above is the case. GL
Old Apr 24, 2024 | 08:50 AM
TxBenzIn's Avatar
2003 SL500 (70,000)
Thank you both - great insight.
Old Apr 27, 2024 | 09:26 AM
BMBLBEE's Avatar
2014 SL63 AMG / 2024 Porsche Macan GTS (Winter beater)
Can anyone provide part numbers for the MB valve cover gaskets and RTV? My 2003 passenger side is leaking and I need it fixed to pass a government inspection to register the car.
Bob
Old Apr 27, 2024 | 10:22 AM
marcd7tx's Avatar
I'm pretty sure MB rebrands the Loctite SI5900 for the breather reseal. The MB sealant is
003989982010
PNs for the valve covers are: the one ending in 321 is for the passenger side where the EGR is located.
1130160321 and 1130160221
But if you're just replacing the valve cover gaskets you could just use something from the auto part store. The sealant is specific for redoing the breathers.
Old Apr 27, 2024 | 10:49 AM
TxBenzIn's Avatar
2003 SL500 (70,000)
003989982010
I found this kit at FCPEuro. Overkill or convenience?
Valve Cover Gasket Kit (FCPeuro)
Old Apr 28, 2024 | 09:43 AM
BMBLBEE's Avatar
003989982010
THANKS - this will be a great help.
The kit noted might be overkill for what I'm trying to repair and shipping to Canada is usually an issue as well but thanks for the link.
Cheers,
Bob
Old Jun 5, 2024 | 03:13 AM
Dubai80's Avatar
S560 w222
Same here
Oil leak on plugs at Cylinder 2. Added (stop oil leak) STP brand and will check ASAP if leak is still present.
Old Apr 14, 2025 | 04:51 AM
yovenim's Avatar
just looking
Originally Posted by TxBenzIn
I had the dealer do a LOF, and a MultiPoint Inspection a couple weeks ago. They noted that the Valve Cover Gasket needs to be replaced. I looked on both sides and didn’t see any signs of leaking. There is nothing on the garage floor either.
I do notice that after I park it, I can faintly smell a burning smell. Could that be related to the acft calculator?
Yes, the burning smell could be from a small oil leak from the valve cover gasket hitting hot engine components. Even if there’s no visible leak or floor spots, a minor seep can still cause that smell. Replacing the gasket and doing the plugs at the same time is a smart move.
Old Dec 31, 2025 | 09:50 AM
Kent agent's Avatar
S600 w222
S600 w222
There are several reasons I took an s600 before the v8
Old Dec 31, 2025 | 06:32 PM
mrvedit's Avatar
2004 SL600
Ha, us M275 V12 owners have plenty of our own problems like 24 spark plugs and $1500 coil packs.
