SL/R230: Hydraulic Pump
Old Apr 22, 2024 | 06:58 PM
Tomcat SL's Avatar
2004 SL55 AMG
Hydraulic Pump
My 2004 SL55 AMG (R230) hydraulic pump is oriented such that I cannot tighten the hose clamp (red arrow in attached picture).
I believe all I want to do is rotate the plastic reservoir without making a mess.
There seems to be one allen head bolt (1.) and some plastic "plug" (2.).
Any secrets on how to loosen up/rotate/retighten the hoseclamp/reservoir?
Thanks,
Tom
Old Apr 23, 2024 | 12:52 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
Tom, by what I can see in the picture, you just need to remove the spare tire to access the hose clamp bolt..! Otherwise you would have to remove the 4 nuts holding the whole assembly in place and lift it for access. Screws 1 and 2 has nothing to do with the hose clamp and reservoir holding.
Old Apr 23, 2024 | 09:43 PM
Tomcat SL's Avatar
2004 SL55 AMG
Thanks, I don't know how it was installed because the hose clamp bolt is facing away/under the clear reservoir...I will investigate accessing it. :-(
Old Feb 4, 2025 | 02:15 AM
yovenim's Avatar
just looking
There seems to be one allen head bolt mm to Inches Conversion (1.) and some plastic "plug" (2.).
Thanks,
Tom
To rotate the plastic reservoir on your SL55 AMG (R230), first loosen the allen head bolt (1) to release the reservoir. Then, remove the plastic plug (2). Once the bolt and plug are removed, gently rotate the reservoir to the desired position. After that, retighten the hose clamp, reattach the plug, and secure the allen bolt again. Be careful not to spill hydraulic fluid during the process.
