SL/R230: Time is up to make the ABC decision
Old May 28, 2024 | 06:23 PM
MarkCan's Avatar
Sl500
@FL SL500
I wouldn’t worry about slightly higher current draw at the moment. That is not the source of your problem. Have the car scanned with a professional scanner. Module could be off due to earlier problems. Not necessarily displayed on the cluster.
Old May 29, 2024 | 06:51 AM
cdk4219's Avatar
95 SL600
Originally Posted by Das Geld 2
The ABC system is the lifeblood of the car. It loses all identity without it.
I guess the r230 black series has no lifeblood or identity then.
Old May 29, 2024 | 10:57 AM
imtheking's Avatar
Former R230, W220 and W221 owner
Originally Posted by evoviiiyou
he is my guy and source as well, when my red ABC dash light comes on! I am kind of looking forward to it to be done with it for the rest of time.
I think he is a community member- his name on here is LLcoolbenz (i think)
Old May 30, 2024 | 12:47 PM
Das Geld 2's Avatar
SL55, S500
Yes, you're totally right!
Let's compare a Black Series car that came with factory coil over spec and R230's with ABC that were ripped out and replaced with aftermarket $1000 coil overs....
Old May 30, 2024 | 06:29 PM
cdk4219's Avatar
95 SL600
It may be worth it to some, not to me. The thousands invested isn’t returned in either comfort or reliability.
Old Aug 15, 2024 | 11:01 PM
LuisV-rod's Avatar
2009 SL 550, 1995 S600
Waiy until you have to deal with the hoses !!!
Old Aug 16, 2024 | 02:24 PM
  #32
elMacko's Avatar
SL 500 2004, Ford F-150-2014
My friend Das, sometimes when you buy a car for $15K knowing that your resale value will be under that, you may not start throwing $$$$ in repairs and upgrades. So, ABC, BCM, and Vario are basically the major headaches on that car, so replacing these systems with durable alternatives at lower cost may be the way to go, but you the owner who values certain systems on the car, just do as you please regardless of the loss of time and $$$. I replaced the ABC, the BCM and really like the ability to go topless and it is a system cheap to maintain...so I will keep that!
Old Aug 16, 2024 | 05:59 PM
  #33
njbiker2008's Avatar
sl 500 r230
I did the same thing then blow a hose that goes under the motor so i went coil overs silvers!
Old Aug 26, 2024 | 10:51 PM
  #34
JoBlow's Avatar
06 SL500
I'm not sure how good the quality of the coil over conversions either. All seem to be chinese supplied, no major brands here.
Old Aug 27, 2024 | 12:40 PM
  #35
brucewane's Avatar
2005 SL600
Originally Posted by FL SL500
I've tried that many times and nothing is changing. I've been fiddling with the Convenience Features Not Available messages and the inaccessible Menu settings for well over a week now. That was what lead me to take a close look at the system battery and to eventually to replace it and to look at the current flow through it. But that all seems to be fine so now I'm wondering if the BCM is flagging the battery as low even when it's not. (I'm assuming that the BCM is what monitors the battery and alerts the other systems but I'm not sure.) Also it's worth pointing out that I haven't had any kind of battery warnings or alerts.
Bobterry said: "The factory specification is for the current to be less <= 50 mA after 20 minutes, and for no reason apparent to me a measurement should be taken with the vehicle locked."
I know and the current in mine didn't go that low but at that point of was just looking any excessive current draw that might be affecting the battery and I thought that 79Ma was low enough. When I get some of the other problems out of the way I will go back and look at that and see if it does eventually drop to less than 50ma and if not, why. I may just need to wait longer for the current to drop. I did have the key in my pocket so possibly it was waking the system up. Do these cars really detect the presence of the keys even when no button was pushed?
What do you mean by "system battery" - the consumer battery in the trunk, or the starter battery under the hood?
If you're going to DIY, you really need some kind of diagnostic code reader to be able to work on these cars. You're completely in the dark without it, you'll be wasting $$$ and time just throwing parts at it blindly. Foxwell NT510 (reviews at the top of this forum) or the Launch CReader Elite are decent budget choices, or you can get a full blown Mercedes Xentry system for more $$$, but still pretty reasonable. Xentry gives you full MB diagnostics, plus the full MB workshop manuals and the parts catalog. For the full Xentry system, I recommend to contact BenzNinja (search for him on this forum), well worth the few extra $$ he charges to provide a reliable system and ongoing support with troubleshooting issues.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
