SL/R230: Passagenger SEAT stuck forward
Old Jun 24, 2024 | 01:07 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
R230 friends and family,
While trying to check the fuses behind the passenger seat, moved it all the way forward. When trying to move it back, it didn't respond...!
If trying to remove the seat seems difficult since the two front bolts are inaccessible. I wonder if it is a way how to move it manually!
Thank you kindly for sharing your thoughts!
Old Jun 24, 2024 | 06:58 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
You have to remove the bottom cushion to get to the fore/aft motor.
Old Jun 25, 2024 | 08:59 AM
elMacko's Avatar
Mike, thanks for the suggestion..! I found an old post that addresses the same issue and here is what they did: I will try that first, then to the hard work!
"My SL-550 had the exact problem with the passenger seat. I carefully pried the seat switch on the R shoulder of the seat up to expose the wiring. You'll need a thin knife blade and patience. Once it is off, turn it over to see three small torx screws. You'll need a quite small torx wrench to remove them and you will not be able to remove the cable connector without unscrewing the mechanism or at least I couldn't. Remove the three screws and you should then be able to unhook the connector. When that is off, you can remove the back cover and see the PC board. Insert a small jewelers screwdriver in the side slot to loosen the PC board from its mountings. Examine the solder connections on the PC board. They will probably look good but the fix is to re-solder them with a precision iron that will let you add a very small drop of solder to each point so any bad one is repaired. Put it all back together and test it. And it worked!"
"Just wanted to say thank you for this, it worked for me. I held the forward door button for a long time as it took several movements to get fully forward. Ditto for the seat fold forward button. Then tried the buttons on the seat and they seemed to make a noise which they hadn't before BUT didn't move the seat. So I returned the seat to where it was originally using the door buttons and then suddenly the seat back / forward worked."
Old Jun 26, 2024 | 08:53 AM
elMacko's Avatar
Mike, the outlined procedure took care of the issue......Seat is back where it belongs..!
Old Jun 27, 2024 | 03:40 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Im glad you got your seat sorted, thanks for sharing all the info and repair to the switch. Can I ask if you tried to press the memory position to see of the seat would move? I know on my little Launch Creader Elite diagnostic, there is a bi-directional control that would power the motors and move the seat without using the switch.
Old Jun 27, 2024 | 09:27 AM
elMacko's Avatar
A1EK, have not tried that yet, will let you know when I get a chance!
