SL/R230: ABC2 pump/pulsating damper
As the pulsating damper is attached to the pump, anyone know whether they come as a complete unit when you buy a reman pump? I’m not sure whether my noise issue is the pump or the damper. However, I suspect that it’s the damper.
I’ve heard that removing the damper from an old pump is not a joyful experience so it would make sense to sell them as a complete unit.
I mean I think that's because MBZ had this stupid policy of the fluid being "lifetime" like the transmission fluid, which has turned out to be completely false in both cases. Idk how if they change the pump they would use the same old fluid and filter. Doesn't make sense.
Sean
IMHO, these dealers believe MB "sealed for life" BS and in the case of ABC cars it can be expensive to believe it. I fail to understand how pumping dirty fluid around a precision hydraulic system is a good thing? MB guys want to fix cars and if dirty fluid burns out pumps or clogs accumulators, they sell more parts and service.
Thankfully this forum has members with knowledge and experience to educate us.
