2007 SL550, 2008 E550, 2011 E350, 2012 Chevrolet Caprice PPV
Vario Roof Help!
Hi everyone, I have discovered the source of my interlock top issues… my left hand side micro switch is missing… previous owner had the top “repaired”. Anyways, where does this sucker run?? I took the hatch off the rear fuse panel but don’t see any corresponding yellow connectors. Kind of stumped here :/.
Originally Posted by MikeJ65
It connects to the main harness in front of the spare tire well.
I’ll be sure to check that this evening. Thank you.. I suspect the previous shop who did the work either cut the sensor and let the wires fall down the pillar. Or they completely removed it and forgot to put it back. It appears the top cylinder was leaking at some point.
