SL/R230: 2009+ Distronic Retrofit
2009 Sl550, 2009 335d, 2005 Corvette C6, 2017 Armada, 2023 Santa Fe
I was looking at what it would take to add distribution to my car. I can’t figure out if the retrofit listed for models prior to 09 is the same. Any help with a parts list?
You will need:-
Distance sensor A2305400062 or A2305401717 or A2305401417 or A2305401817 or A2305400162
Kit of bolts, etc. A0015406317
Wiring harness A2305402110
Control switch A2308212851 or A2309050100
You will need a STAR diagnostic system to code and enable.
You will need to change the Mercedes star emblem on the front grill to be Distronic compatible..
Good Luck !
Good Luck !
You will need:-
Good Luck !
Good Luck !
