SL/R230: Blue Hydraulic fluid leak?
Old Aug 6, 2024 | 02:19 PM
vailchef's Avatar
380 SL, 550SL
Hello All. I have a 2007 550 SL. I just returned from a week away and there is ań ounce or so of blue hydraulic fluid on the garage floor, right under the right front end . Before I take it in, does anyone have a general idea what I should be looking for? Thanks all!
Old Aug 6, 2024 | 04:13 PM
brucewane's Avatar
2005 SL600
Are you sure it's hydraulic fluid? Right front blue liquid is often windshield wiper fluid, a common problem with R230s.
Old Aug 6, 2024 | 04:19 PM
vailchef's Avatar
380 SL, 550SL
That was my first thought. It’s oil though. Thanks!
Old Aug 6, 2024 | 08:06 PM
SemihG's Avatar
2007 SL550, 2008 E550, 2011 E350, 2012 Chevrolet Caprice PPV
Could it be fluid from the motor mounts? I do know those are hydraulic filled, try brake boosting the motor while in gear.
Old Aug 8, 2024 | 01:41 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
I'm with @brucewayne on this one. Common location they leak from the headlight washer nozzles or lines.
Old Aug 14, 2024 | 09:27 PM
vailchef's Avatar
380 SL, 550SL
Okay. Turns out it’s radiator fluid after all… now I have to sort out from where. Thanks all
Old Aug 15, 2024 | 10:06 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Check the aux. coolant pump. It is over on that side and they tend to corrode and leak.
