SL/R230: REVISED r230 Conv Top Fluid Fill HELP
Can anyone who has knowledge please respond...
In the attached img, I'm pointing to the bolts/nuts at the four corners of the platform the vario pump sits on. The instructions say "loosen A7/5 RVC [UVS] hydraulic unit" until filler screw is exposed. I do not see any further info, but I'm assuming you loosen these nuts until the entire unit can be slightly tilted at the reservoir end until the filler screw is accessible. Is this accurate? Will the entire unit "tip" just a bit at an angle so it is slanted just enough to add fluid? Having never done this before, I'd like someone with experience to provide some knowledge on how this works. A video would be great, but I have not seen one ON THE REVISED r230 with the filler screw on the end of the reservoir.
Thanks for any help!
