SL/R230: rear view camera and bluetooth phone
Old Oct 23, 2024 | 07:51 PM
Jim Chambers's Avatar
2000 SL5000
Looking at a 2007 SL550.. Wife demands a rear view camera and hands free phone. Don't want to spend the money to go newer than R230. Is there an aftermarket solution?
Old Oct 23, 2024 | 11:51 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
There definitely are aftermarket solutions. I had a rear camera and a cell phone link installed into my 2006 CL500 many years ago. Local auto radio/stereo shop did the install. I don't recall the manufacturer but they are out there. Perhaps with a bit of online searching you'll find some options. Good luck!
Old Oct 24, 2024 | 08:00 AM
doitwright's Avatar
280SL
If you have the SD card slot in the top of your factory head unit (I think 2007 had it) then this thread explains how to do it. I did it on my 2009 SL550.
https://www.benzworld.org/threads/20...ssues.2796090/
You will need SDS to activate the feature already built in. For MB to design the system with the capability and not just put the camera in is a mystery.
Old Oct 24, 2024 | 01:45 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Yes that works in 2009-2012 models with the Comand APS NTG2.5, but the 07-08 still used the old Comand APS NTG1.
Not sure if those NTG1 units had the capability for adding backup camera and the OEM bluetooth is a pain to install and expensive. For this instead, I ended up buying one of those bluetooth dongles that connect to the AUX input, but I don't think the CL, S, and SL with those head units had AUX input.
