SL/R230: Soft Close Trunk
Old Nov 12, 2024 | 10:25 PM
VTP99's Avatar
05 SL500
Soft Close Trunk
[img alt="Coil packs that the yellow air line supplies
2 wire connector
Right coil operators the ( hockey puck ) actuator
Unlocks trunk
Left coil operators the ( white tank ) actuator
Soft closes trunk "]https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1471/pxl_20241111_150259886_4c5961652d7588f5c1558be39ef 40177142ca0fc.jpg[/img]
Coil packs that the yellow air line supplies 2 wire connector Right coil operators the ( hockey puck ) actuator Unlocks trunk Left coil operators the ( white tank ) actuator Soft closes trunk
[img alt="Micro switches below the hockey puck actuator
Top switch is first lock position
Bottom switch is soft close position
Switches are powered by the 3 wire plug
Common / 1 / 2"]https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/pxl_20241113_025051705_mp_a1e1d46dbd7f2210b823a1c4 f60a1e1957e31238.jpg[/img]
Micro switches below the hockey puck actuator Top switch is first lock position Bottom switch is soft close position Switches are powered by the 3 wire plug Common / 1 / 2
Old Nov 12, 2024 | 10:26 PM
VTP99's Avatar
05 SL500
Old Nov 12, 2024 | 10:28 PM
VTP99's Avatar
05 SL500
Old Nov 13, 2024 | 12:15 PM
VTP99's Avatar
05 SL500
Testing the soft close actuator
