SL/R230: Brak palenia sie Check Engine
(Jeśli po uruchomieniu pozostaje światło silnika, wskazuje na problem, a skaner jest potrzebny do sprawdzenia kodów, które będą kierować się problemem i jego wyleczeniem.)
If when key is in run position with engine off, the light does not illuminate, the bulb may be burned out. Does the engine seem to be running fine?
If my check engine light did not light up, and the engine runs well I would not take anything apart, I'd just leave it alone, I think I can tell when the engine is needing help. At that time I would check for codes.
