SL/R230: Thrust arms and balljoints torque specs
Old Dec 11, 2024 | 01:54 PM
Antonov's Avatar
SL65
Post Thrust arms and balljoints torque specs
Hi guys,
I'm soon replacing both front thrust arms and one ball joint on an SL350 with normal coil suspension. Has anyone got the a picture with the torque specs for this job?
Many thanks!!
Old Dec 11, 2024 | 07:51 PM
marko69's Avatar
'01 CLK 430 cab, '04 SL500 (230K miles)
Deleted, I posted a torque spec picture for an SL500, never mind.
Old Dec 11, 2024 | 07:55 PM
Antonov's Avatar
SL65
Thanks amazing! Many thanks!
Old Dec 11, 2024 | 07:58 PM
Antonov's Avatar
SL65
I guess it should be the same as for the SL350, shouldn't it?
Old Dec 11, 2024 | 08:07 PM
marko69's Avatar
You replied pretty quick to that. lol. I deleted the post as I didn't notice that it was for an SL350, I don't know if it's gunna be the same or not. I'll post the pic here again just in case.
Old Dec 14, 2024 | 04:58 PM
Tom Manning's Avatar
2005 SL 500 R230
Mark, I lost my WIS in a computer change so would be appreciative if you could send up the diagram for the SL500 too. TIA - Tom
Old Dec 14, 2024 | 06:13 PM
marko69's Avatar
Hey Tom, the diagram above should be for the SL500. I verified a few of the numbers that they matched the WIS.
Old Dec 15, 2024 | 06:00 PM
2005 SL 500 R230
Thanks for that. Going to rebuild my front end soon. BTW neither of our hounds are actually crazy - just puttin' it on for the camera!
Old Feb 10, 2025 | 05:11 PM
Tigger23's Avatar
SL500
Hi marko69
Do you have the same torque diagram for the rear suspension. Just rebuilding my rear end.
many thanks
Old Feb 10, 2025 | 08:06 PM
marko69's Avatar
Sorry, can't remember where I got that diagram. I can't find one like it for the rear.
Old Mar 7, 2026 | 07:58 PM
Der.Unibrow's Avatar
SL500
This diagram is partially incorrect. Everything on the steering knuckle is 50Nm + 60 degrees. Also the ABC strut to the spring control arm (strut's lower end) is 110Nm.
