SL/R230: Do I have Soft Close Problem?
In the event I do have a soft close issue, I have read the DIY FIX. When doing the fix after testing for leakage, do I need to disconnect the negative battery or pulling the fuse would be sufficient?
Has anybody with the Auto Close feature done DIY FIX? Are the steps the same for cars with Non-Auto Close and Auto Close? With the Auto-Close feature, I would think that disconnecting the cable from the switch would have to be done unless you are disconnecting the convenience battery.
But first find the leaks and fix them.
