SL/R230: Key fob locking & unlocking
New to the threads, so please be gentle! I purchased a used 2008 SL 550, and I cannot get the doors to lock or unlock with the remote key fob.
Spoke to the prior owner, and he said that it should work fine. I have read threads / posts etc. about this problem, but cannot figure out how to correct.
Figured I would ask for advice here, below are my tests / attempts to correct:Key Fob:
Neither door fobs go down when pressing lock button, but the alarm activates
Neither door fobs go up when pressing unlock button, but the alarm deactivates
Trunk opens as normal
Batteries in fob are brand new
Tried resetting the unlock method by holding unlock and lock (several times)
Keyless Go
Door arms when pressing handle button, but neither fob goes down
Passenger’s door fob does not (manually opening with door handle causes fob to go up).
Also, the dash button function is different than the fob. Locking with the dash button just locks the doors, interior compartments stay unlocked because the car is assumed to be occupied.
Bottom line is that you almost certainly have a leak in the system. My first guess would be passenger door, but you can test each line with pressure and vacuum to properly diagnose it.
One other thing. For keyless go equipped cars, door unlock when grabbing the handle is by an electric solenoid, not pneumatics. Locking with the button on the handle is pneumatic.
Passenger door held neither
Noticed this when I took disconnect it from the unit. It appeared to me that some one tried to glue this back on the PSE pump.
I would have to take the pump a part to see, but didn't know if anyone here has had this issue before?
Or do I need to buy a whole new PSE unit?
