SL/R230: Vario roof leak - replace cylinder
Welp... It finally happened. I noticed that the roof cylinder is leaking and I now have those bubbles on the trim above the passenger door window. I'm guessing that means that the cylinder in the roof section (top lock cylinder?) is leaking. Is my assumption correct even though the leak showed up on my passenger seat by the passenger window? This now explains some hydraulic fluid I found on the passenger seat about two weeks ago. I chalked it up as an accident because I had been working on the door earlier.
I've done the trunk cylinder and that one wasn't too bad. How does this one compare to the trunk lid cylinder in terms of replacing it?
Another option is to get a new or rebuilt cylinder, remove the rod like you would to do the o-ring fix, and just interchange the entire rod assembly. I have seen some rebuilt rod assemblies for sale, but they are not easy to find.
