SL/R230: A/C drier blocked? Can't recharge system
Now, I fill system with around 1 can of freon, get about 85 PSI on both low and high side. Turn on the compressor with DAS and the low side drops to 30 PSI and the HIGH side also drops to around 30 PSI and stays there after the compressor is turned off. ?? With compressor off, DAS shows B12 press sensor at 101 PSI. The sensor is right at the drier input. Right at the drier output is the HIGH side port which shows 30 PSI, not good. Used another set of gauges, same thing. Looks like a blocked drier to me.
While removing the drier, I removed the output line of the drier and got a small puff, basically nothing (30psi). I figured there would be more coming out of the input line (101psi) and there was, a lot more. Sort of confirms the 101psi reading. If the drier was not blocked I should have gotten all that freon from the output side of the drier.
I installed a new drier and no change, same scenario.
I blew air into the replaced drier both ways and it went through just fine, no blockage (using air) I believe normal operation would be liquid.
What am I missing here?? Whatchall think?
Some visuals
A/C working good now.
(Getting the compressor out is one of the most frustrating jobs I've had to do on this car.)
