SL/R230: Another ABC Question
Old Jun 30, 2025 | 05:18 PM
hogger453's Avatar
SL550
Good day.
The question:
My right front sits just slightly lower than my left front side when the engine is running. I'm going off visually wheel well clearance.
During the night resting it sits even a little lower than while running.
No error messages, no leaks, rides great.
Anyone else experience this.
Any informative information is greatly appreciated.
Thank you.
Old Jul 1, 2025 | 11:08 AM
HLG600's Avatar
2009 SL63 AMG
Could be a couple different things going on.
A bit of sagging overnight is often caused by tired or damaged seals in the valve block.
Variation in ride height, assuming no mechanical issues, could potentially be sorted by re-calibrating it.
Do you have access to MB STAR / Xentry?
Also, is the variation the same in the raised position as it is in the lowered position?
Old Jul 1, 2025 | 06:34 PM
hogger453's Avatar
SL550
Thank you for the response.
Makes perfect sense.
Regarding the MB STAR / Xentry can you or someone direct me with a link on a reliable source on where to purchase? I'm going to purchase one regardless.
When I get home next week I'll test your thoughts on the raised and lowered position, if it is the same.
Stay tuned.
Old Jul 1, 2025 | 09:05 PM
mrvedit's Avatar
2004 SL600
The BenzNinja will have you buy a specific Chinese clone, your choice of laptop and he will then install the software remotely.
He will also help you remotely diagnose problems.
Old Jul 4, 2025 | 03:06 PM
hogger453's Avatar
SL550
Thank you.
Originally Posted by UltraSpeed
I am in the process of ordering everything up.
Became a lifetime member.
So, I raised the car in position one and two. Really no discernable height variation.
Just started the process with benzninja.
