SL/R230: Trunk/boot stuck closed
I saw utube showing access by removing 3rd Brake light, has anyone tried this? Any suggestions, brake light cost £15 so would be cheap solution. Thing is utube looks authentic just looking for practical advice before trying
Rgds
Stan ( yelnats69)
If not it is not intuitive how it works.
Turn key 90 degrees then pull the release handle while lightly lifting.
The key does not open the trunk, just unlocks it.
If the key does not turn, try some penetrating oil in the lock, and GENTLE persuasion by twisting key.
Does the key turn a FULL 90 degrees?
Does the handle feel like it is acting on something when you pull on it
Another possible option if you can get to the engine compartment is to hook 12v to the front pre-fuse box, but you should seek more advise before doing this as I do not have it's electrical drawing with me to give good advice.
Rgds
Stan
