SL/R230: flush the ABC fluid
Old Jul 20, 2025 | 10:12 PM
JoBlow's Avatar
06 SL500
flush the ABC fluid
did it yesterday and I can't believe how much difference its made. The old fluid was black for sure. Not only does the car going up and down much faster than it did before, I swear the ride quality has improved, noticably. Is that even possible? I understand the bias to feel the results of work that we've done, so maybe. Anyway, for a 30 minute job it's no brainer. 1/2" barb and 2' of 1/2" hose. And a bucket.
Old Jul 23, 2025 | 11:36 AM
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
I flushed the ABC like you have 6+ times. It does help but you don’t actually get the fluids behind rear valve block to flush unless you crack a rear bleeder valve. When I replaced the rear Accumulator I found old black fluid.
Doing a flush off the return line to the tank is better than nothing but the rear valve block (and lines behind) need a bleed to dump the old fluid.
Even after pushing 2 L thru the rear system it still was slightly discolored just not black.
You’re fighting the pressurized Accumulator that stores a fair amount of fluid
I got the car with >80k mi on it and maybe if the original owner had done at least one/two full flushes it would’ve helped but my main problem was the front valve block/struts and the entire electrical control system.
Any fluid flushing helps. Keep up the good work
Old Jul 31, 2025 | 09:49 PM
JoBlow's Avatar
06 SL500
Do you drain with with the car running or off?
Old Aug 18, 2025 | 12:57 AM
Car has to running and best done by two people; One to turn the car on and off while someone cracks the valve. You have to be careful not to drain the entire system and have the hydraulic pump go dry
Old Aug 18, 2025 | 02:21 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
old ABC fluid carries a lot of metal in it, its acidic, it thickens which causes wear to seals and the pump from trying to push it around, and it heats up faster which is a compounding issue
most ABC issues are preventable in the long run with regular maintenance of the fluid and accumulators. its a special interest area of expertise for me here locally
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Aug 20, 2025 | 07:10 AM
aeginc77's Avatar
2005 SL 600, 2004 Jaguar XKR, 1998 Corvette, 1975 Porsche 914
I am preparing to change the rear accumlator and valve block. When should I do the flush before or after I change the accumlator and valve block?
Old Aug 21, 2025 | 08:54 PM
JoBlow's Avatar
06 SL500
are we talking about bleeders on each shock absorber or somewhere else?
If the shocks is lt like bleeding brakes? Furthest from pump first??
And can you just bleed the shocks (or wherever) and just replace that amount of fluid? (not total replacement of system fluid)
