SL/R230: Very Odd Occurrence
Thank you.
Its bizarre actually.
The only thing I can think of is the battery replacement may not have been compatible with the electrical system?
Also, it might be a symptom of other electrical problems such as alternator, voltage regulator or other components.
I am sure there are modules in the electrical system that may be suspect.
I agree with you on suspect electrical issues. However, the battery is less than 14 months old and is an OEM MBZ part. But my biggest question is why, if there were suspect electrical issues, I wouldn't have seen some more minor issues that could have led up to it, yet I didn't. This is why I have no idea why, out of the blue, this could have happened.
Balt. Yes, I will investigate any BMS issues.
I thank you both very much for your knowledge, input, and advice.
What code is causing the "Check Engine" light?
IMHO, considering the age and problems with these cars, every owner should keep a code scanner in the car. You can buy a MB specific one from "Launch" for as little as $120 or with a bigger screen for $160. All on Amazon. This make is easier to get help on this forum.
Correct, my bad. It's the EIS and not DIS. I thought I read in a part list that it was called a DIS. However, when I retrieve my car, I'll review the manifest and return to update you.
Almost got a R230 but top quit on test drive. Did me a favor. C-Class is full of metal springs where many MBs have hydraulic and air lines and servos. Dodged some bullets but obviously a rougher ride.
When I see "DAS" on this forum, I'm pretty sure we are referring the the DAS/Xentry diagnostic scanner as used by MB dealers for these cars. Some (many?) members here have Chinese clones of the system-software installed on laptops.
As I understand it, the EIS has a permanent security code. For the car to start, the ECU has to have been programmed with a matching code. For the shifter to work, it also has to have a matching code; don't know if this can be programmed easily, but it is contained on a relatively easily swappable "Chip". For a key to work, it also has to have a matching code. The DAS/Entry system lists a function for making keys, but I suspect it needs additional hardware. I have used my Autel IM-608 scanner with key programmer to make an additional key from a blank. It takes time (15 minutes) to crack the security code. I have used the KESS3 tool to program a "virginized" ECU to the EIS after first reading trhe code from the original ECU.
Is it still called a “distributor”?
