SL/R230: TCM swap out
Old Nov 14, 2025 | 03:13 AM
mstuart10006's Avatar
2004 sl500 and 1999 slk 230k
TCM swap out
Can i puchase a used transmission control plate with valve block and solenoids and swap it out for my existing faulty unit on my 2004 sl500 convertable
Old Nov 14, 2025 | 07:16 AM
cdk4219's Avatar
95 SL600
Not if it is a 722.9, the DAS won’t recognize the plate and it won’t go into gear
Old Nov 14, 2025 | 07:42 AM
TCM swap out
Thank you for your reply so that option appears to be a non starter so im now going to replace the solenoids in my own unit in the hope that will work.
thanks again
Old Nov 15, 2025 | 06:54 PM
mrvedit's Avatar
2004 SL600
The many transmission codes you listed the other day sounds more like the entire trans is disconnected or the TCM had a total failure. As mentioned, trans fluid can seep up the harness into the TCM and damage it. This does not sound like bad solenoids. For one, not every one would fail at once.
Old Nov 16, 2025 | 09:10 AM
cdk4219's Avatar
95 SL600
I don’t believe the 722.9 has that particular issue, but I could be mistaken
Old Nov 16, 2025 | 04:01 PM
mrvedit's Avatar
2004 SL600
OK, perhaps that doesn't happen with the 7-speed 722.9.
In any case, the OP's extensive list of transmission codes does not indicate problems with the solenoids. Either the harness is disconnected, a fuse related to the TCM is blown, or a major computer malfunction in either the TCM or the "chip" in the conductor plate.
To guess (!) I suspect the conductor plate. I have no idea who, other than a dealer, can program a replace plate, but I suspect various independent tuning shops can do it, perhaps even sell a pre-programmed plate.
