SL/R230: lots of codes - Seeking potential explanation
Can such behavior be attributed to the failure of one component? If so, whats your guess as to the culprit? The seller was amazed that I had found what I did and was shocked when multiple components werent functioning. He's a car collector with multiple MB's and he has owned this SL for the past two years and supposedly bought it from his uncle, so I am leaning that many of these issues are new and related. Interested to hear your thoughts
IMHO, you need to reset the codes, start the car, drive at least around the block and check for codes again.
The ABC "Low Pressure" code will be a concern if it comes back, which is likely. All the other ABC codes are due to the low pressure.
I do have my suspiciions regarding the installed battery. Yes it is new, but it is a Duralast suggesting owner install. Not sure if it is the proper AGM battery.
WIth the ABC, top and electrical codes the car has issues. I am trying to decide if its worth the effort to make an offer to take it off his hands. He is motivated and I am fairly willing to accept a challenge. I am more nervous about the apparent electrical gremlins than the ABC and top as I have sorted the ABC on my CL and there's decent documentation available to sort thru the top issues.
Fortunately you are in a big city where there are many similar cars, independent shops and likely plenty of expertise.
Your decision comes down to how much you want the car, price and you willingness to fix things. Likely figure it going to cost another $3000-$5000 in the first year to get it working very vell.
What engine model are you looking at?
