SL/R230: Seeking help with PSE diagnosis
- I had errors at the door locks, solved that as the actuator covers were cracked. They still pass air but not enough to throw the code.
- I have a contiining code at the trunk self closer. I think I fixed the self-closer, as it holds air when tested by mouth and no hissing noise when in operation. Again, still results in code, even when not in use.
- The mulricontour seats throw codes. I have yet to dive deep into them. The individual bladders were recently holding air (except one, I capped the line feeding it). The driver seat will not respond, aside from the solenoid click from the interior/back of the seat (I have the rear covers off). There is no air from the supply hose that connects beneath the driver seat when the MCS buttons are pushed. Each bag in the passenger seat will fill and immediatley deflate. Again, they were recently holdng pressure.
- With key in ON position, there appears to be a continuous subtle hiss coming from the center console, near armrest. This is with engine off, both doors open, and HVAC off.
So any insight would be appreciated but here are some particular questions I have:
1. If the PSE pump is designed to respond to demand at the individual components and all components are at rest, why does it continuously run?
2. If the trunk mechanism is holding air (at least more effectively than the door lock) and functioning, why is it throwing codes?
3. Is there any reason why one seat's MCS function would fill the bladders but not hold the air? and why the other seat will not produce air at the supply line when demanded by the MCS buttons (this is when codes are cleared)?
4. What is the source of the continuous subtle hissing noise at the center console with key on and all components at rest?
5. I have read about an air reservoir but cannot find one, aside from those integrated in the MCS bolsters. Is there one and where is it?
If anything is leaking the pump is going to run. Sounds like you have at least the continuous glove box leak.
My research the other day for another thread concluded that typical pressure is more around 15psi, maybe max of 30, not 40.
To help you here is some correct info about these PSE pumps (many of the replies you see are wrong).
The pressure from the pump must be 40 psi minimum. When the output is less than 40 psi, the locking / unlocking will operate but the trunk soft close fault will be set and stop working until power is cycled off and on to the PSE.
To check if your PSE is working correctly or not, please do the following.
Disconnect both electrical plugs from the PSE. Disconnect both grey clip with pipes.
Connect the large plug (10 way), the PSE will run and air will come out of the outlet marked IZV, cover that IZV port with your finger, the PSE will stop. When you remove your finger air will stop coming out of IZV. Then one of two things will happen, either the pump will stay stopped or it will restart and air will come out of the MKL port, if this happens cover the MKL port and the PSE will stop as long as you hold your finger on the MKL port.
If the PSE does anything else other than the above then it is faulty.
Some further info:-
The trunk mechanism must be able to hold 39 psi (actually 2.7 bar as set in the PSE).
The “continuous subtle hissing noise” is probably the little fan in the climate (heating / AC) control panel in the centre console.
Some cars have an air reservoir in the trunk floor. See photo.
Some further info:-
However the pressure is low as you said it was 30 psi, but the pump in the W220 unit you have might be OK, have you tested it?
The IZV is the internal locking, that is glove box, storage boxes behind seats and the arnrest box.
MKL is the pressure for the seats.
Assuming the pump is not the issue, what do you think would be the cause and solution?
Once you have these sealed try the PSE pump and we can take it from there.
