SL/R230: OPTICAL DECODER & BYPASS LOOPS
Old Mar 30, 2026 | 02:51 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
GUYS AND GALS,
I HAVE DECIDED TO BITE THE BULLET AND REPLACE THE OLD COMMAND 2.0 WITH AN ANDROID SYSTEM. HAVE MOST OF THE INFO, BUT WOULD LIKE TO KNOW:
1.-HOW MANY LOOPS DO I NEED. MALES OR FEMALES?
2.-I ASSUME I HAVE 3 ITEM S IN THE LOOP, THE COMMAND, THE CD AND THE TELEMATIC. WONDER WHERE THE TELEMATIC IS LOCATED.
3.-DOES ANYONE HAVE AN OPTICAL LOOP SCHEMATIC?
THANKS AGAIN FOR YOUR SUPPORT!
Old Mar 31, 2026 | 07:51 AM
imtheking's Avatar
Former R230, W220 and W221 owner
Originally Posted by elMacko
GUYS AND GALS,
See if this helps. He installs an aftermarket on a R230
and this
Old Mar 31, 2026 | 07:15 PM
g0rsq's Avatar
SL500
You need to know if you have MOST or D2B fibre system.I presume by age it is D2B.
Are you going to keep the original amplifier?
If all the other components on the fiber are OK then you can just leave them connected and will be fine. However if you read about the D2B system, it can be awkward, and some people find they need to connect the D2B adapter direct to the amplifier with a singe fibre cable (loop).
Another option is to remove the D2B completely, and wire the new headunit either to a new amplifier, or directly to the speaker cables after removing the original amplifier behind driver/passenger seat.
You only need "loops" if you are removing components from the fiber system to "fill in the gap" of the missing component in the fiber loop.
File Type: pdf
File Type: pdf
Old Apr 4, 2026 | 08:36 PM
bnastyer's Avatar
2007 SL600
Based on your profile you have a 2004 SL500, right?
That means most likely not a MOST fiber connection, you will need D2B fiber converter and you will need to follow the Seicane install video shared earlier as you will most likely also require a 6M cable run from dash to rear CD changer area.
D2B adapter
