SL/R230: ABC still sagging after valve block rebuild
Recently picked up an 04 SL55 w/ 50k miles. The car would drop overnight after several hours, starting in the front left corner and then the rear left would drop. The right side will stay up altogether no matter how long. I rebuilt the front valve block using the upgraded seals everyone speaks of, but now it seems that the pressure leak is worse. After shutting the car off, the front left corner is completely slammed down after only about an hour and the rear left follows shortly after. Is there something I could have missed while doing the rebuild? Or should I begin to look in other areas for the problem? I’m very confused. Any help would be appreciated. Thank you.
