SL/R230: Help needed
Old Jan 31, 2005 | 02:20 PM
PA55AMG's Avatar
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
Help needed
Yesterday, I was at my sisters house showing her my sl and demonstrating the roof mechanism. When closing the roof, the trunk lid would not go down without some manual help. Her driveway is a sharp upward incline. I later opened and closed the roof on the level, without problems. Has anyone experienced this? If the consumer battery was a little low, would this happen? The car was running at the time. It seemed as though the motor could not get the trunk lid started on it's downward swing. Any help would be appreciated. Thanks.
P.S. I just found out there is TSB#P-77-37-21 concerning this issue. The tsb came out in Mar-04.
Old Jan 31, 2005 | 03:20 PM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
I have never experienced this problem but then again, the slopes have been minor that I have opened my roof on.
Can you not call the Dealer and see what he says about the TSB?
Old Jan 31, 2005 | 03:26 PM
PA55AMG's Avatar
I have a call into the dealer, but they were very busy, so I will have go tomorrow and see what the tsb says. Some brands are very tight about releasing tsb info to customers. So far, this dealer has been great about releasing this kind of info. They printed out several for me last week.
Old Jan 31, 2005 | 04:41 PM
If you have any problems which I suspect you won't, let me know. I can get it.
Good luck.
Old Jan 31, 2005 | 04:42 PM
PA55AMG's Avatar
I just found out the tsb refers to a fluid leak in the system. So, I am back to the inclination situation. Anybody else have this problem? Lovin, next time your in the city, could you try this on a steep hill? Thanks.
Old Jan 31, 2005 | 04:47 PM
Shall do. Not sure when I will get there but when I do, I absolutely will. There are plenty of hills to check it on.
Old Jan 31, 2005 | 05:45 PM
PA55AMG's Avatar
Thanks Lovin, there is also the possibilty of cold weather in this scenario, but it was only 35 when this happened. The roof worked fine when back on level ground.
Old Feb 1, 2005 | 09:42 AM
carlosfernandez's Avatar
SL500 2003 previous/ E350 2007 actually
Hi PA500sl:
will you post the tsb that youare refering to, I think my car has that brake fluid problem. Thanks in advance.
Old Feb 1, 2005 | 10:48 AM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Web site with limited data
I found this web site with limited dat on auto recalls and technical service bulletins.
http://www.alldata.com/TSB/35/0435BRAN.html
Old Feb 2, 2005 | 06:45 AM
PA55AMG's Avatar
Carlos, the tsb refers to a hydraulic fluid leak in the roof mechanism not the brakes. You can go to your dealer with those tsb numbers from alldata.com, and they should print them out for you.
Old Feb 2, 2005 | 12:36 PM
Thanks for the info to all of you.
Old Feb 4, 2005 | 05:33 PM
jasab's Avatar
SL500 '05
Red face
The mechanism is either not man enough to work on hills, or it senses it and shuts off.
My mum and dad live on a hill, the roof works intermittently.
When I got the car and started showing it off outside their house, it taught me a lesson.........show off on level ground only.
Old Feb 6, 2005 | 12:07 PM
I know the car has a sensor for the floor if it to slow but if probably that it has more sensor for the inclination of the car that stop or look the roof mechanism.
Old Feb 6, 2005 | 03:09 PM
jasab's Avatar
SL500 '05
Got to be careful, imagine trying to operate whilst in traffic on a hill and it stopped half way down. Not cool
Old Feb 6, 2005 | 03:32 PM
PA55AMG's Avatar
Mine stayed in the fully open position. After I ran the motor for a few seconds, I was able to just push the trunk lid down too an almost closed position. At that point I pushed the switch and it closed and locked. I wonder if the motor just gets it started and then uses the weight of the trunk lid to close.
