SL/R231: Transmission Issue?
Question: are you sure it is shifting all the way down to first gear? Or is it shifting into second gear. I think if you are in the normal (Comfort) setting it may be shifting only down into second gear.
Also, this may be that the engine control computer is learning the way you drive and may be making adjustments. This may account for why it seems like the symptom only appeared recently.
Sport mode shifts to 1st gear and blips the throttle a bit, not like my Ferrari, but just a bit you can notice. Economy shifts the car into 2nd gear and starts from 2nd as well.
MB
However, I'll correct myself concerning the RPM. I wrote 2500 in my prior post. It's nowhere near that. It's just enough to feel the shift and it's effect on slowing down.
Also, if you free-wheel-it -- in neutral -- down a long decline for a mile or so, and then drop the transmission back into gear, can you do any damage to the transmission? I've tried this a few times and it seems to work perfectly, without any popping or sudden movements.
Thanks for your thoughts on this.
I have ready many times that putting torque-converter automatic transmissions into neutral does not actually save gas. Because the engine idles at a lower rpm when in gear than it does when in neutral. The articles say that idling at the lower rpm while in gear actually uses less gas.
Does the engine use more fuel just keeping the torque-converter spinning while in gear?? Don't know. I am just quoting the articles.
Are there any trannie experts out there?
and you feel the change down, that's good because it brakes the car, I luv
it, when driving normally it changes smooth without jerks.
Mines an AMG.
Mine wasn't a blip, rather total loss of power, without warning. This wasn't a performance feature but a malfunction and which we identified in 3 other SLs
Be careful . This is a real problem and one MB know about but are not rectifying it. Other members on this web site have experienced this problem as well. Don't be fooled or conned into paying to have repaired as it is a MB liability
Dealership said this was normal tranny behavior, and from what I'm reading here on this website/forum .. seems intrinsic to the 7spd tranny...
it's very annoying
I take your point but remember as your car has shown up this kind of problem that what has happened to my friends and I are likely to happen to you also . It is simply a latent defect. What happens in my car is the car simply fails 'to take off' and there is total loss of power and can compromise you when you will least expect it. It happened to me as I was entering a roadway with a car coming and I was almost taken out. Not good for the blood pressure! My engineer says that this happens if you apply your accelerator sharply and it appears what can happen then is that selector , on occasions, ( ie intermittently) gets confused and the selector selects what is described as a false neutral but rather interestingly is that the only way you can get the car to function then is to turn off the engine and allow the system to 'reset'. You can't therefore apply manual mode without turning off the engine and this is what makes the whole problem a most serious issue. So be careful particularly when overtaking , entering motorways or making a quick getaway from the kerb as you could let yourself in for a serious drop
So be careful
Philip
Just had my transmission valve body replaced under warranty after fighting with MBUSA about my "rough shifting" -- now I have a much smoother shifting transmission. They also updated the software.
Had to involve MBUSA in NJ before the dealership would take me seriously.
So be careful
Philip
absolutely sounds like a nightmare issue to have on a very expensive car or any priced car, for that matter!
I hope MB does the right thing and looks for this issue in other cars on the conveyor belt...
