SL/R231: driver's seat massager broken, fixed
just an fyi for you, my fellow r231 brothers and sisters -- my driver's side seat massager quit working. i would set it to level "4" for example, and it would work intermittently for a minute and then reset itself to"0" all by itself. i took it to the benzo dealer, and they fixed it. the deets are below in case they might be helpful for you in the future should you have the problem and need to cite chapter and verse for your service advisor. all is well now - 5,000m and going strong. love the car more every day. cheers. /a
"function test l/f seat massager, found it turns off after a minute and will not turn back on, performed quick test, current and stored code 9ed271 in l/f seat control unit, performed guide test, per guide test r+i seat, disassemble back rest cover and cushion, replaced m94 with massage bladders, clear codes and function test seat. pad front se 1 231-910-27-16."
Ours also stops massaging, but I don't think the number goes to 0. Will have to check that out.
Also.....I hear a whooshing noise in the dash when making a turn....wonder if there is an air line loose? It's actually kind of a soothing sound....like waves on the ocean....LOL
