SL/R231: Vibration
Old Oct 7, 2013 | 09:28 AM
jjomaa's Avatar
2011 ML63 2013 SL63
Vibration
I just recently replace a rear passenger side rim after hit a colossal pot hole and now im noticing a slight vibration at higher speeds in the steering wheel and in the pedal.
N e ideas
Old Oct 7, 2013 | 08:37 PM
California John's Avatar
2022 AMG SL63
Sure sounds like suspension. Whether it means the alignment has gone off, you've bent the wheel, or something else is wrong, but I would certainly have it looked into.
Old Oct 8, 2013 | 09:39 PM
red308's Avatar
2013 SL63
I had that happen a few years ago. Bent the wheel. Had to get a new wheel which completely fixed the problem.
Old Oct 14, 2013 | 12:36 PM
jjomaa's Avatar
2011 ML63 2013 SL63
So took it in for an alignment and to our surprise the SAI is out by 11 I believe and needs a new strut, knuckle and upper control arm and hub/bearing... That being said do u think there is a chance of possible frame damage!? Just curious as the car is made out of aluminum?
