SL/R231: Trunk Lid
Old Jan 4, 2014 | 01:15 PM
JackLogan's Avatar
2013 SL550, 2013 GLK350
Trunk Lid
There are two push buttons on the trunk lid of my 2013 SL 550 that are viewable when it is raised. One is to close the lid. The other is to close and lock. Shouldn't these buttons light up when the hood lid is open? Mine do not light.
Also, shouldn't the key fob close the lid? Mine does not.
Appreciate your help,
Old Jan 4, 2014 | 06:36 PM
California John's Avatar
2022 AMG SL63
My two buttons do light up. The light is soft but they are definitely illuminated. And no my key fob also does not close the trunk lid. However you can close the trunk lid from the same lever on the driver's door that opens the trunk. That's a nice feature.
Old Jan 4, 2014 | 08:51 PM
JackLogan's Avatar
Thanks, John.
Old Jan 5, 2014 | 05:37 AM
BenzV12's Avatar
W212 FL
Kufatec makes a device that enables to close the trunk by pressing the keyfob buttons .
However, I find it a bit overkill though
Old Jan 13, 2014 | 04:12 PM
Gunther's Avatar
1988 560SL (sold); 2001 E430 (sold); 2004 SL500; 2009 CL550
If you don't want to use the buttons on the trunk lid to close it you can always use the foot feature, it opens and closes the trunk as well.
Old Jan 13, 2014 | 06:36 PM
happyinboca's Avatar
2019 e 450 cabriolet
The foot feature only works about 20% of the time for me.
Old Jan 13, 2014 | 07:26 PM
2022 AMG SL63
100% for me.
Old Jan 14, 2014 | 02:23 AM
mikey94025's Avatar
2015 S550 Coupe
The foot feature works 100% for me once I learned the correct/best way to do it. It's a straight in-and-out motion, not left-and-right, and a steady speed. I think the instructions in the owner's manual also helped (I didn't read them at first, as usual).
Old Jan 14, 2014 | 06:12 AM
Gunther's Avatar
No issues here either - in and out under the car, not across. But isn't that the trick to most technology? Understanding how it works? Then you don't have a pre-ordained expectation that doesn't match up to reality.
Old Jan 15, 2014 | 09:58 PM
i was sweeping across not using the in / out method - worked every time since - Thankie !
