SL/R231: What could this be?
Old May 11, 2014 | 02:33 PM
branmin's Avatar
Sold 06 CLS500. SL550 09. SL550 2013. Own C6 Corvette heavily customized garage queen 2005.
What could this be?
When I make a left turn...you can clearly hear a wooshing noise coming from the dash area, but my wife then thought it was coming from somewhere else. It only makes this sound on a left turn.
It's like something is moving from one side to another, or something sliding from one area to another. Cannot fathom out what this is?
Any ideas? tia
Old May 11, 2014 | 06:18 PM
BenzEsq's Avatar
2014 SL550, 2014 ML63
Do you have your active bolsters turned on? If so, when i make turns in an otherwise quiet car, I can hear a swooshing sound come from the seats expanding and contracting.
Old May 11, 2014 | 10:04 PM
branmin's Avatar
interesting reply...you could be right...its just that I have never heard this before..yes I do have the active bolsters on......
Old May 12, 2014 | 08:31 PM
branmin's Avatar
leaking airbag.....
At Mercedes today and the noise is a leaking airbag!!
Also for others who like myself are having the problem with the disc brakes continually squeaking.......they have refused to replace again....last had the front disks replaced in January and they are still bad.......they today told me that MB are working on a fix(supposedly) and will not replace until told to do so.....having new tires put on today, so not exactly pleased, but what can I do? Also, as I have noticed quite a noise with the wipers..was expecting new ones to cost about $75.00..oh no...$150.00 to replace... What I said(after just 13 months from new) and was told that in the florida heat they usually wear out after a year.............and should be replaced at least twice a year
yeah right...................
hmmm...the joys of owning a good car:-)))
Old May 12, 2014 | 09:04 PM
Wolfman's Avatar
Super Moderator
Same here but mostly on right turns.
This maybe a leak in the bladder or valve as it only occurs on the passenger seat and both seats are set to active.
I am bringing the car in for service next week so I'll have that checked out.
For some reason I thought there was a service bulletin out for that but i maybe mixing that up with something else... I'll check
Old May 13, 2014 | 06:15 PM
BenzEsq's Avatar
branmin, are you talking about the SRS protection airbags or the air bladders in the seat bolsters?
Old May 13, 2014 | 07:20 PM
branmin's Avatar
I believe they were referring to the airbags
Old May 13, 2014 | 07:34 PM
Wolfman's Avatar
Super Moderator
There is no air going into SRS airbags. Can you confirm that. Thanks
Old May 14, 2014 | 09:57 PM
branmin's Avatar
Ok Wolfman..when I collect the car, will see exactly what it was and let you know.
Old May 14, 2014 | 10:01 PM
Wolfman's Avatar
Super Moderator
Thanks! Mine is going in next week. The noise in the passenger seat is really bugging me...
Old May 17, 2014 | 12:12 AM
branmin's Avatar
It was the right bladder in the drivers bolster that was leaking even though I was told it was an airbag problem. 4 days waiting for parts..so make sure if you have the same problem and it sounds like it, that they get these parts in advance.....
Valve block....231-800-10-78
Clip....000-914-20-00
Old May 17, 2014 | 12:26 AM
Wolfman's Avatar
Super Moderator
It was the right bladder in the drivers bolster that was leaking even though I was told it was an airbag problem. 4 days waiting for parts..so make sure if you have the same problem and it sounds like it, that they get these parts in advance..... Valve block....231-800-10-78 Clip....000-914-20-00
Thanks for the update!
Old Mar 15, 2016 | 11:53 AM
DoctorV8's Avatar
2005 CL65
Sorry to dredge up an old thread, but my wife's 2013 SL has been doing this on and off since new. It's back in the shop again for the same whooshing noise, even after having the bolster replaced and some of the lines as well.
Very annoying. Wonder how common this is?
