SL/R231: Extended Warranty..sounds too good to be true?
Old Oct 16, 2016 | 12:35 PM
branmin's Avatar
Sold 06 CLS500. SL550 09. SL550 2013. Own C6 Corvette heavily customized garage queen 2005.
So as some know here..I have decided to wait until 2019 for the hopeful great new shape as opposed to getting the 2017 version. I have a 2013 SL550 and done 40 thousand miles, warranty up 30th March 2017...I do about 10-12 thousand a year but no more....
I can't quite work out how they calculate the years(and I might be wrong) but the 6 year 75K..does this mean another 2 years from my warranty end? So say from April 1st 2017 I have another 2 years and have to be under 75 thousand miles?
Anyway, would appreciate those that understand these things please would you have a look at the coverage and tell me what you think and when would be the best time to take this out?
I know that these are basically just insurance policies and many think this is just an expensive add on but the Salesman assured me that MB would accept Lexus and once before I paid for coverage and sure enough had some major problems just after the normal warranty ended and saved myself a lot of money....
6 year 75000 = $2385
6 year 100000 = $3480
7 year 75000 = $3135
7 year 100000 = $4510
All are Lexus Platinum warranties with a ZERO deductible. When you decide I will need your VIN, mileage, name, address and phone number. Once I have the policy typed I will call and you can pay over the phone. Very easy process.
Drive with confdence knowing you are protected by Lexus Extra Care.
Lexus Extra Care, designed with you in mind.
Let Lexus Extra Care simplify the unexpected events in life. We have crafted a protection plan that conveniently fits your needs
and can help insulate you from surprise services. We know your Lexus is more than just a vehicle and that is why we want to help
you protect it. Keep your luxury vehicle protected with a plan built for you.
Benefits and Peace of Mind:
• Protection after your Lexus warranty expires1
• Repairs using Lexus-approved parts, performed by factory-trained technicians keeping your Lexus at peak performance
• 24/7 roadside assistance
• Deductible Options
Smart. Simple. Exceptional. For more information contact your Lexus dealer.LEXUS EXTRA CARE– Platinum VSA
Platinum VSA covers the cost of mechanical breakdown of the parts listed below after your vehicle’s warranty expires. 2
Your vehicle’s Limited Powertrain Warranty covers only those parts listed in BLACK text.
ENGINE
All internally lubricated components and: Balance Shaft; Camshaft; Crankshaft;
Crankshaft Pulley; Cylinder Heads; Engine Block; Engine Mounts; Engine
Oil Reservoir; Engine Oil Reservoir Pump; Equipment Drive Shaft; Exhaust
Manifolds; Flexplate; Flywheel; Idler Pulley; Intake Manifold; Oil Pan; Oil Pressure
Switch; Oil Pump; Oil Sending Unit; Piston; Seals and Gaskets; Supercharger;
Supercharger Intercooler; Tensioners; Timing Belt; Timing Chain; Timing Cover;
Timing Gears; Turbo Intercooler; Turbo Wastegate; Turbocharger; Valve Covers;
Water Pump; Air Control Valve (ACV); Air Pump; Crankcase Ventilation Valve;
Exhaust Gas Recirculation Valve; Exhaust Manifold Heat Insulator; Exhaust Pipe
Gasket; Mixture Control Valve; Oil Cooler; Oil Filter Bracket Subassembly;
Pair Valve (Reed Valve); Supercharger Bypass Valve; Supercharger Relay;
Thermal Vacuum Valve; Thermostatic Valve; Three-Way Catalyst Converter;
Vacuum Switch; Vacuum Switching Valve; Vacuum Transmitting Valve
MANUAL TRANSMISSION
Transfer Case Components (All internally lubricated components) and: Clutch
Master Cylinder; Clutch Release Cylinder; Gears and Shafts; Hoses, Lines and
Tubes; Seals and Gaskets; Shift Linkage and Cables; Transfer/Transmission Case;
Transmission Mounts; Clutch Pedal Subassembly; Control Position Indicator
Subassembly; Master Cylinder Reservoir; Radial Ball Bearing (for Clutch
Release) and/or Clutch Fork; Shift Lever Boot and/or Retainer; Shift Lever Knob
AUTOMATIC TRANSMISSION
and: Hoses, Lines and Tubes; Seals and Gaskets; Shift Linkage and
Cables; Solenoids; Torque Converter; Transfer/Transmission Case;
Transmission Mounts; Vacuum Modulator; Shift Lever Knob
AXLE ASSEMBLY
(Front, Rear, Four-wheel and Allwheel Drive): All internally lubricated
components and: 4x4 Actuators; Axles and Bearings; Center Support Bearing;
Constant Velocity Boot Band; Constant Velocity Joints and Boots; Differential
Carrier Assembly; Drive Axle Housing; Drive Shaft; Hubs; Locking Hubs;
Seals and Gaskets; Thrust Washers; Universal Joints; Viscous Coupling
SUSPENSION
(Front and Rear): Bushings/Bearings; Control Arm Shafts; Electronic Suspension
Actuator/Motor and Compressor; Front and Rear Coil Springs; Front and
Rear Stabilizer Bar; Front Leading Arm; Front Spring Assembly; Front Spring
Shackle; Radius Arm; Spindle; Spindle Support; Steering Knuckle; Strut Rod;
Suspension Spring Shackles; Sway Bar Link; Torsion Bar Spring; Upper and
Lower Ball Joints; Upper and Lower Control Arms; Upper Arm Shaft
STEERING
Gear Box internal components and: Bushings/Bearings; Center Link; Horn
Contact Ring; Hoses, Lines and Tubes; Idler Arm; Knuckle Stopper Cover; Pitman
Arm; Power Steering Pump; Power Steering Pump Pulley; Rack and Pinion; Seals
and Gaskets; Steering Column; Steering Column Coupling; Steering Column
Shaft; Steering Dampener; Steering Gear Box and Pump Housings; Tie Rod End
FUEL SYSTEM
Air Flow Meter; Carburetor; Charcoal Canister; Diesel Fuel Injection
Pump; Electric Fuel Pump; Electronic Fuel Injection System; Fuel Filler
Opening Lid Hinge Spring; Fuel Injectors; Fuel Pressure Regulator; Fuel
Pump; Fuel Sending Unit; Fuel Sensors; Fuel Tank; Throttle Body
COOLING SYSTEM
Coolant Level Sensor/Tank; Cooling Fan Relay; Cooling Fan Sensor; Engine
Coolant Temperature Switch or Sensor (at radiator); Engine Cooling Fan Motor;
Engine Fan; Engine Fan Clutch; Engine Fan Motor; Engine Fan Shroud; Equipment
Drive Pulley; Fan Bracket Subassembly; Radiator; Seals and Gaskets; Thermostat
AIR CONDITIONING/HEATING
Air Conditioning Heater Box Assembly; Air Conditioning Lines and Tubes;
Air Conditioning Pressure Switches; Air Temperature Control Programmer;
Blower Motor; Blower Motor Resistor; Compressor; Compressor
Clutch Assembly; Compressor Pulley; Condenser; Condenser Fan and
Motor; Cooler Control Switch; Damper Servo; Defroster Control Cable;
Evaporator; Evaporator Temperature Sensor; Expansion Valve; Heater
Control Head; Heater Control Valve; Heater Core; Idler Pulley; Pressure
Regulator Assembly; Receiver/Dryer; Schrader Valve; Seals and GasketsBRAKES
Anti-Lock Braking/Traction Control Actuator, Pump and Motor; Brake
Booster; Brake Hoses, Lines and Tubes; Brake Pedal Subassembly; Disc
Brake Calipers; Load-Sensing Proportioning Valve; Master Cylinder;
Parking Brake Cable; Parking Brake Control Handle Assembly; Parking
Brake Lever Subassembly; Parking Brake Pedal Subassembly; Proportioning
Valve; Rear Brake Backing Plate; Seals and Gaskets; Wheel Cylinders
HYBRID
Actuator Assembly Shift Control; Hybrid Vehicle Generator Assembly; Hybrid
Vehicle Motor Assembly; Hybrid Vehicle Transaxle Assembly; Transmission Input
Damper Assembly; Battery Computer Assembly; Battery Current Sensor; Circuit
Breaker Sensor; Combination Meter Assembly; Combination Meter Computer;
Hybrid Vehicle Battery Blower Assembly; Hybrid Vehicle Battery Blower Motor
Control; Hybrid Vehicle Battery Thermistor; Hybrid Vehicle Control Computer;
Inverter Assembly with Converter; Main Switch Assembly; Power Source Control
Computer Assembly; Power Steering Electronic Control Unit Assembly; Power
Steering Gear Assembly; Shift Lever Position Sensor; Skid Control Computer
Assembly; Steering Column Assembly; Transmission Control Module
ELECTRICAL
Alternator; Automatic-Off Headlamp Sensor, Timer and Switches; Automatic
Shoulder Belt Motor and Switches; Automatic Temperature Control Unit;
Battery to Ground Cable; Battery to Starter Cable; Blower Motor; Blower Motor
Resistor; Charge Warning Relay; Clutch Starter Interlock Switch; Convertible Top
Motor; Cruise Control Actuator/Servo; Cruise Control Sensors and Switches;
Cruise Control Vacuum Motor; Defogger Relay; Distributor; Door Control
Relay; Engine Coolant Temperature Gauge and Sending Unit; Engine Coolant
Temperature Receiver Gauge and Sending Unit; Engine Cooling Fan Motor;
Engine Tachometer; Fuel Gauge and Sending Unit; Fuel Receiver Gauge and
Sending Unit; Guide Rail Limit Switch; Headlamp Washer; Headlight Control
Relay; Horn; Horn (for theft deterrent); Ignition Coil; Ignition Switch Lock
Cylinder and Key Set; Integration Relay; Lamp Failure Indicator Sensor; Lock
Cylinder Set; Main Relay; Manually Operated Switches; Oil Pressure Receiver
Gauge and Sending Unit; Power Antenna Motor and Cable; Power Door Lock
Actuator; Power Mirror Defogger; Power Mirror Motor; Power Seat Motors;
Power Sliding Door Motor; Power Window Motor/Regulator; Rear Shock
Absorber Control Actuator; Retractable Headlamp Motor; Shoulder Belt Drive
Motor; Smart Entry and Start System Switch, Sensor and Electronic Control
Unit; Spark Plug Resistive Cord; Speedometer; Starter Motor; Starter Solenoid;
Stop Light Switch; Sunroof Cables; Sunroof Motor; Taillight Control Relay; Turn
Signal Flasher; Unlock Warning Buzzer; Windshield Washer Pump; Windshield
Wiper Link Assembly; Wiper Control Relay; Wiper Motor; Wiring Harnesses
COMPUTERS AND ELECTRONICS
Airbag Sensors; Airbags; Antenna Cord; Anti-Lock Braking/Traction
Control Computer and Sensors; Automatic Shoulder Belt Computer;
Body Control Module; Circuit Opening Relay; Compact Disc (CD) Player;
Cruise Control Computer; Electronic Ignition Unit; Electronically Controlled
Transmission/Transfer Case Computer and Sensors; Electronically Modulated
Suspension Computer; Engine Control Computer; Front Seat Airbag
Assembly; Graphic Equalizer; Knock Sensor; Navigation System; Power
Mirror Electronic Control Unit; Power Seat Computer; Progressive Power
Steering Computer; Radio Tuner; Steering Sensor; Stereo Component
Amplifier; Sunroof Control Computer and Relay; Tape Player; Tilt/Telescoping
Steering Computer; Traction Control Computer; Trip Computer; Variable
Induction System; Vehicle Security Computers and Sensor; Wiper Module
ADDITIONAL COMPONENTS
Accelerator Pedal and/or Bracket Subassembly; Accelerator Pedal Rod
Assembly; Back Door Lock Assembly; Convertible Roof Hook; Door
Handles; Door Lock Cylinder; Front and Rear Door Lock Assembly; Front
Seat Belt; Glove Compartment Door Lock Cylinder; Glove Compartment
Door Latch Subassembly; Hinges; Hood Lock Assembly; Hood Lock
Control Cable Assembly; Hood Support Assembly; Rear Seat Belt; Reclining
Seat Back Adjuster; Removable Roof Lock Handle; Seat Track Assembly;
Shoulder Belt Guide Rail Assembly; Sliding Roof Drive Cable; Sliding Roof
Guide Rail; Tail Gate Lock Assembly; Tilt Roof Lock Handle Assembly
THESE ARE THE ITEMS NOT COVERED:
Accessory Drive Belts; Batteries; Body Panels; Brake Linings, Pads and
Shoes, Rotors and Drums; Bumpers; Carpet; Chrome; Clutch Friction Disc
and Pressure Plate; Dash Cover and Pad; Door Fabric; Door Trim; Filters;
Fluids; Glass (including Windshields); Headliner; Heating Hoses, Lines
and Tubes; Hoses; Hybrid Vehicle Battery Pack; Hybrid Vehicle Battery
Plug Assembly; Hybrid Vehicle Relay Assembly; Hybrid Vehicle Supply
Battery Assembly; Interior and Exterior Trim and Moldings (including but
not limited to: Ashtrays, Covers, Cup Holders, and Vents); Lamps, Light
Assemblies/Housings, and Lightbulbs; Nuts, Bolts, Clips, Retainers, and
Fasteners; Paint; Rust and Corrosion Damage; Seat Covers; Sheet Metals;
Shiny Metals; Spark Plugs; Structural Framework and Welds; Tires; Vacuum
Hoses, Lines and Tubes; Weather Stripping; Wheels and Rims; Windshield
Wiper Blades (Rubber component); All interior and exterior cloth, leather,
and stitching including convertible tops and/or vinyl tops including but not
limited to: any vibration, deterioration, discoloration, disfigurement, warping,
fading, staining, stretching, ripping, punctures, tearing, and/or scratches24/7 Roadside Assistance
YOUR TRUSTED ROADSIDE COMPANION
Drive confident with 24/7 Roadside Assistance. If
the unexpected happens to occur, our VSA will help
get you back up and running with:
• Towing to the nearest Lexus dealer
• Battery jump starts, flat tire and lockout assistance
• Delivery of up to 3 gallons of fuel
• Coverage anywhere in the continental US and
Canada
Roadside service provided by AAA and its affiliated
clubs.
Travel Protection
BACK IN BUSINESS AND BACK ON
THE ROAD
If you’re unable to drive your Lexus due to the
mechanical breakdown of a covered component,
substitute transportation and travel protection
benefits will provide reimbursements of:
• Up to $50 per day for car rentals or other
substitute transportation.3 Maximum of 5 days per
occurrence.
• Up to $100 per day for lodging and meals if you’re
more than 150 miles from home. 3 Maximum of 5
days over the life of your Agreement.
Eligibility
NEW
New Lexus vehicle less than 4 years old and up to
50,000 total vehicle miles.
USED
Used Lexus vehicle within current plus 9 model
years old and up to 125,000 total vehicle miles. See
your dealer for eligibility requirements on non-Lexus
vehicles. Used Vehicle plans available through your
Lexus dealer only at the time of used vehicle purchase
or lease.
Old Oct 16, 2016 | 06:50 PM
branmin's Avatar
anyone?
