SL/R231: Hydraulic fluid leaking around right front and right rear tires
Old Apr 3, 2017 | 10:52 AM
roger2600's Avatar
SL550
Over three days, I have leaked approx 1 quart of clear fluid under the right side of the car - in front of right rear tire and behind the right front tire. Any idea what this is?
Old Apr 3, 2017 | 11:54 AM
budoman's Avatar
2014 SL550. 2018 GLE43 AMG SUV
What year is your 550? Does it have ABC.
Old Apr 3, 2017 | 11:59 AM
roger2600's Avatar
SL550
2012 - it does have ABC. 24k miles.
Old Apr 3, 2017 | 12:09 PM
budoman's Avatar
Does the fluid have a smell and is it oil like or watery? Do you have an extended warranty? If its the ABC it could leaking valves, broken line or leaking struts which is very common. It could be a brake line as well. Try to identify the fluid.
Old Apr 3, 2017 | 01:47 PM
roger2600's Avatar
SL550
Fluid seems more watery. I get no ABC error messages when I start the car. I recently had the retractible top repaired - does that have fluid? I checked fluid levels under the hood & they seem to be OK.
Old Apr 4, 2017 | 09:09 AM
budoman's Avatar
Yes the top has "fluid". Why don't you visit a mechanic because it seems like a bad leak. These cars all need extended warranty which pays for itself usually with one repair. Best of luck!
Old Apr 4, 2017 | 09:47 AM
Wolfman's Avatar
Super Moderator
2012 is the prior model unless you live outside the US
