SL/R231: R231 Broken Center Console Storage Compartment
This seems to be very common on these vehicles - the rolltop storage behind the center console and roof controls breaks along the track for the rolltop door; it was on my CPO at least.
Unfortunately my CPO has a high-end designo type of leather that is basically unavailable from Mercedes-Benz at this time, so I had the dealer send me a standard black with black threading storage compartment to match the base black leather that most of these cars have:
My stock designo sliding door and cover were still completely intact:
The little sliding door is removable from the bottom of the storage compartment:
Two flexible plastic prongs with rubber nails keep the sliding door from sliding off of its track - these can be gently pried out with pearing knives to remove the sliding door:
Here is the new console piece with my old designo sliding door attached:
Here it is fully-assembled, good-as-new:
You will need to remove the top piece for ease of re-insertion behind the center console; also removal of the auxillary battery upper trim piece and opening of the driver's side storage lid will help; here it is installed:
Reinsertion of the center console piece is very difficult - watch out that you don't snap off the red lights from the fiber optic cables here or you won't get red lighting around where you should.
-CCOOK
-CCOOK
TennesseeZ4 (04-24-2017)
Great post! The dipstick that installed the window tint on my 2017 SL knelt on my unit and collapsed the sliding door even after I warned him to be careful. Lucky for me, and him, nothing was broken and I was able to manipulate the door back in the tracks and it works as original.
Super Moderator
Received 3,171 Likes
I don't think this is a common issue, but I can see how it can break if somebody applies pressure.
If I have opened this thing more than two-three times in the last 4 years I would be surprised
Helpful post though!
17 SL550 (Designo Edition), 08 C300, 13 Mini Cooper, 17 Macan GTS, 18 720s
MB
