SL/R231: How to turn off AC
Press this till the light goes off, and the climate control will operate as normal but will not enable the AC compressor. So if you're driving top down and don't want the AC to come on, you can push this button. Other functions including ventilation work completely normal other than the AC compressor not running.
When you look closely at the 'Zone' button on the right side, you'll see the word 'OFF' is printed on the LOWER PART OF THAT ZONE BUTTON.
Pressing 'OFF' (lower part of the Zone Button), WILL TURN THE ENTIRE CLIMATE CONTROL SYSTEM OFF, INCLUDING THE A/C AND THE FAN!.
Note #1 - This is normally, the button to press for 'Top Down' Driving on the 231, unless for some reason you actually prefer to keep your Climate Control System 'ON' for top down driving!....
Note #2 - When you are ready to turn your Climate Control System back ON again, just press the 'Auto' Button, (the large black button located on the left side of the 231's Climate Control Area).
Note: This is normally, the button to press for 'Top Down' Driving on the 231, unless for some reason you actually prefer to keep your Climate Control System 'ON' for top down driving!....
