SL/R231: Thinking about a 17 SL450
1. Can the top be dropped with the key remotely?
2. Was Magic sky control an option? It does have the sunroof.
3. It will be a CPO car so I'm not too worried but is there anything I should check for?
I'm likely trading in my 14' S550 on this which I'm a little sad about but my boss says I have too many cars already.
Yes, Magic Sky was indeed optional, but I recommend it. If the one you are looking at has a sliding panel used to expose the sky, then you have the 'standard' 231 sunroof.
I have to wonder if red color you're looking at is actually Mars Red if indeed it's a 2017 model. I believe Mars Red had to be dropped sometime during 2017 due to clear coat peeling and there are MB Tech Bulletins out for cars painted that color, even some lawsuits over the problems with that color as well, because MB has flatly refused to repaint any cars over this issue, despite the fact that the paint application was clearly flawed by the MB Factory.. As I understand it, the clear coat finishes won't adhere to the paint chemistry of tge Mars Red color and with time and sun exposure the paint surface soon begins peeling off
MB seems content to offer only the Cardinal Red now which is available as an extra cost Metallic Red color. However, it actually has a 'more orange' appearance compared to the Mars Red which was a non-metallic lacquer finish in earlier model year 231's.
Yes, Magic Sky was optional. If there is a slider open to expose the sky, you have the standard sunroof.
I doubt the red color you're looking at is Mars Red if indeed it's a 2017 model. Mars Red had to be dropped prior to that due to clear coat peeling and there are MB Tech Bulletins out for cars painted that color, even some lawsuits over the problems with that color as well, because MB refuses to repaint over the issue. Seems the clear coat finishes won't adhere to the Mars Red color and with time and sun exposure you get paint surface peeling off
MB replaced Mars Red with Cardinal Red which is an extra cost Metallic Red color, but with a 'more orange' appearance compared to Mars Red which was a non-metallic lacquer finish.
We just did 1000 miles back from Florida and if I told you the mpg we got, you would accuse me of making a mistake. Make sure the last scheduled maintenance has been performed. Ours was, but if it had not been, it was a little pricey.
The ONLY thing I have found so far that I think is lacking is the sound system. Whoever designed it must have been deaf. My Expedition has A MUCH MUCH better system by Sony. It is one of the worst sound systems I have ever heard in a newish model car. I have not figured out exactly what I am going to do with it. Something from Radio Shack would be better.
I don't like not having a spare either, but will live with it.
From 2014 MY thru and including OP's 2017 MY, both were offered (in the US).
OP's question was not about if it is useful (to some it is not and its fine). The question was if car/key has this ability. The reply to OP's question was false.
Some people don't like them (probably never tried one) but the ability to open close with one press and also from a distance are worth the price alone. As mentioned by others, seat adjustment - mine is set to move the seat back and up when I switch off (easier entry /exit) and move to the driving position when I start up. There are about 15 options on the car that can be set up with the SmartTop
IMO a must have if you can get it.
Again, to the OP: ABC was standard on all 2003 through 2012 SL’s sold in the USA and the cars rode beautifully. For some ridiculous reason, MB made the system a $4K+ option on all non-AMG (SL63 & SL65) SL’s starting in 2013. Since it is not a “flashy” option that a customer can visually see, virtually no dealer ever ordered the option on a car for stock. Since the SL450 was the “bargain” SL, they sure as hell would not order one with ABC, unless a customer specifically, special ordered such a car.
When I ordered my 2019 SL450, I first drove the 550, but found that I actually much preferred the ride & handling characteristics of the lighter V6 over the heavier V8. With ABC, it is an amazing package and I highly recommend it..........IF you can find one.
