SL/R231: Seat balance
For the seat's balance control, which I don't think I've ever used -
Select Balance by turning the COMAND controller and press to confirm.
A scale appears and shows the current setting. Positive values indicate the heat output for the seat backrest, negative values indicate the heat output for the seat cushion. The intensity is indicated by an
orange bar in the stylized seat above the scale.
The values stand for:
0 - backrest and seat cushion are heated equally to the maximum level
1 to 3 - the heat output to the seat cushion is reduced in one-third increments
-1 to -3 - the heat output to the backrest is reduced in one-third increments
I think you can also find a searchable text version of the operators manual on the internet.
Good Luck
Gary
