SL/R231: Front wheel speed sensor.
Yes, you'll need to remove the inner fender liner....
Good Luck
In my case, the failure caused all sorts of strange issues, the most serious was the roof wouldn't close. Apparently the failed sensor was signalling that the car was still doing 50mph so too fast for the roof to operate.
Russ
Car.
Run flat indicator inoperative
ABS anti skid currently unavailable
Engine warning light illuminated along with others appertaining to above list.
Scanner.
Right front wheel sensor sub fault
The right front wheel speed sensor has a malfunction. There is a signal fault or the message is faulty.
Thanks once again for all your help.
